[postgis-users] Extending Linestrings
Julio Galindo
juliogalindoq at gmail.com
Mon Apr 16 22:21:19 PDT 2007
Leticia,
I note that it can be improved a little bit, the first loop starts in 0
instead of 1:
CREATE OR REPLACE FUNCTION ExtendLine(eje_ geometry, bound_ geometry)
RETURNS geometry AS $$
-- version: alfa , by Julio A. Galindo, April 17, 2007:
DECLARE
b_ geometry = boundary(bound_);
dist float;
max_dist float = 0;
n_points int;
pto_1 geometry;
pto_2 geometry;
first_pto geometry;
last_pto geometry;
u_1 float;
u_2 float;
norm float;
result text = 'LINESTRING(';
BEGIN
IF GeometryType(eje_) NOT LIKE 'LINESTRING'
OR GeometryType(bound_) NOT LIKE 'POLYGON' THEN RETURN NULL; END IF;
-- First Search how far is the boundary: (worst case)
pto_1 := StartPoint(eje_);
pto_2 := EndPoint(eje_);
FOR i IN 1..NumPoints(b_)-1 LOOP
dist := distance(PointN(b_,i),pto_1);
IF dist > max_dist THEN max_dist := dist; END IF;
dist := distance(PointN(b_,i),pto_2);
END LOOP;
-- Now extent the linestring:
pto_2 := PointN(eje_,2);
u_1 := X(pto_2)-X(pto_1);
u_2 := Y(pto_2)-Y(pto_1);
norm := sqrt(u_1^2 + u_2^2);
first_pto := MakePoint(X(pto_1)-u_1/norm*dist,Y(pto_1)-u_2/norm*dist);
n_points := nPoints(eje_);
IF n_points > 2 THEN
pto_1 := PointN(eje_,n_points-1);
pto_2 := PointN(eje_,n_points);
END IF;
last_pto := MakePoint(X(pto_2)+u_1/norm*dist,Y(pto_2)+u_2/norm*dist);
result := result || X(first_pto) || ' ' || Y(first_pto) || ',';
FOR i IN 1..NumPoints(eje_) LOOP
result := result || X(PointN(eje_,i)) || ' ' || Y(PointN(eje_,i)) || ',';
END LOOP;
result := result || X(last_pto) || ' ' || Y(last_pto) || ')';
-- Find the final Linestring:
b_ := intersection(GeomFromText(result,SRID(eje_)),bound_);
RETURN b_;
END $$
LANGUAGE plpgsql
STABLE
RETURNS NULL ON NULL INPUT;
On 4/17/07, Leticia <lgomez at itba.edu.ar> wrote:
> Julio, THANKS!
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Julio
> Galindo
> *Sent:* Tuesday, April 17, 2007 1:53 AM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Extending Linestrings
> Hi Leticia,
> I create the following function for your problem, please test it
> carefully, I only made two test (at the end):
> -- version: alfa , by Julio A. Galindo, April 17, 2007: juliogalindoq at gmail.com
> DECLARE
> dist float;
> max_dist float = 0;
> n_points int;
> pto_1 geometry;
> pto_2 geometry;
> first_pto geometry;
> last_pto geometry;
> u_1 float;
> u_2 float;
> norm float;
> BEGIN
> FOR i IN 0..NumPoints(b_)-1 LOOP
> END LOOP;
> first_pto :=
> END IF;
> END LOOP;
> RETURN b_;
> END $$
> LANGUAGE plpgsql
> STABLE
> Test 1:
> select asText(extendLine(geomFromText('LINESTRING(5 5, 12
> 12)',-1),GeomFromText('POLYGON((0 0,15 0,15 20,0 20,0 0))',-1)));
> astext
> LINESTRING(0 0,5 5,12 12,15 15)
> The solution is good, because the line is at 45 degress
> And the same function can work with a general linestring (many points):
> select asText(extendLine(geomFromText('LINESTRING(5 5, 12 12, 13
> astext
> LINESTRING(0 0,5 5,12 12,13 12,15 12)
> Let me know if you improve this simple function.
> Regards,
> Julio A. Galindo Q.
> Topogen Ltda.
> La Paz, Bolivia
> On 4/16/07, *Leticia* <lgomez at itba.edu.ar> wrote:
> Hi community,
> I need to "extend" a linestring in another one. The new linestring must be
> obtained such as their new extremes are the intersection of it with a
> polygon that contains it. The original linestring is composed of only a
> linear segment.
> Is there a simple method to do this?
> I need the other one:
> The original linestring is not always vertical u horizontal.
> Thanks in advance,
> Leticia
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070417/1c919621/attachment.html>
