[postgis-users] psql:lwpostgis.sql:48: ERROR: could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.1": /usr/local/pgsql/lib/liblwgeom.so.1.1: undefined symbol: pj_transform
Frank Koormann
frank.koormann at intevation.de
Tue Apr 17 03:25:19 PDT 2007
Stefan,
you should run a "make distclean" before collecting configure/make
output to reset the sources.
However, why have you moved your libproj.so.0 from /usr/local/lib to
/usr/lib?
If you do so, you should specifiy the location already with the
configure step. Editing makefile.config just before make install is too
late.
HTH,
Frank
Frank Koormann | ++49-541-335 08 30 | http://www.intevation.net/
Intevation GmbH, Osnabrück, DE | Commercial Register Osnabrück, HR B 18998
Managing Directors: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
