[postgis-users] box3d intersects
Fernando Carter V
fcarter at csc-chile.com
Wed Apr 18 10:00:56 PDT 2007
Mark, thanks for your info, and I look up the sources and probably I'm
goint to have my own implementation for this and some other 3d funcions
that I need, so perhaps, I should send send the post to postgis-devel.
Regards Fernando
> On Mon, 2007-04-16 at 15:46 -0400, Fernando Carter V wrote:
>> Hi, I'm trying to obtain the cube that results from intersects 2 box3d
>> objects, I used intersects function but the result is not 3d, it only
>> 2d,
>> is the function incomplete? or I'm I doing it the wrong way.
>> Help is apreciated
>> Fernando.
> No, you're doing it correctly. To the best of my knowledge, PostGIS/GEOS
> don't yet support 3D operations.
> Kind regards,
> Mark.
> postgis-users mailing list
