[postgis-users] TopologyException: side location conflict
Stefan Zweig stefanzweig1881 at web.de
Mon Apr 23 03:35:11 PDT 2007
hi @ all,
i have following problem with the postgis WITHIN method:
i am trying to check whether some polygons from one layer/table are within a polygon from another layer/table and i am doing this with this sql command:
SELECT p."POSTCODE"
FROM _countys b AS b, postcodes AS p
WHERE b."NAME"='florida' AND p."the_geom" @ b."the_geom" = true
AND WITHIN(p."the_geom", b."the_geom") = true
this works fine but takes i while to be procedured. so i wanted to make the within check faster by simplifying the source geometries (EPSG: 4326):
SELECT p."POSTCODE"
AND WITHIN(simplify(p."the_geom",0.001), simplify(b."the_geom",0.001)) = true
but then i get the following error:
NOTICE:  TopologyException: side location conflict (-81.0351,26.6027,26.6027)
ERROR: GEOS within() threw an error!
SQL Status:XX000
i am wondering why the within operator does not work with simplified coordinates / geometries.
btw.: i does not seem that this error occurs with any within/simplify usage, only in some cases.
i appreciate any help.
stefan
_______________________________________________________________
SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
