[postgis-users] PostGIS 2.0 Wishlist
ValiSystem vali.system at free.fr
Tue Apr 24 10:36:25 PDT 2007
On 23 avr. 07, at 21:32, Paul Ramsey wrote:
> FYI, I'm working on the overall wishlist document at this URL:
> http://docs.google.com/Doc?id=dg99qr76_2dgt26j
>   Paul Ramsey
>   Refractions Research
>   http://www.refractions.net
>   pramsey at refractions.net
>   Phone: 250-383-3022
>   Cell: 250-885-0632
		Hello,
	I saw that you plan a nearest neighbor implementation for PostGIS
2.0. Last year, two students worked for me on that subject, i've been
thinking to give you the result (my company owns the copyright, and
we don't plan to do any business with this stuff), but i wanted to do
a cleanup, checking the code and do some improvement before posting
it. But i didn't take the time, and be sure that i'm sorry.
	I've been talking about that last month on IRC, to see if someone
were interested, someone answered positive, but i'm on a rush a work
and i did not worried about that anymore.
	Anyway, the algorithm is the Hjaltason & Samet one [1], and as far a
i tested it, it was pretty good. But the current implementation has
many problems :
  - it's all commented in french, and even some parts of code are in
french (damned students)
  - the implementation works only with BBOXes, and not the actual
geometry. AFAIK it could be possible to use the distance() function,
but it needs to plays with datatypes to find the accurate
implementation.
  - the function is not integrated to postrgesql correctly, you
cannot use it in query, only in one call, where you give tables
names, etc as parameters and even some attributes name might be hard
coded. Nothing critical, but dirty job to be done.
   - it has been written somewhat quickly, by novice programmers.
But, the good news are :
  - there has been a worry of quality, since the student took care to
write it in VC1 by himself.
  - it has worked correctly without visible bug on a 100 000 rows
table in a small amount of time (i don't remember the exact values of
the benchmark).
For the ones who are interested, the algorithm used is a kNN one (k
Nearest Neighbors), so that you can get one or several results,
ordered by distance.
To sum up quickly, the general algorithm plays with the R-Tree, it
explores it in depth (choosing the correct branches), and fill in an
array while going back up. When the R-Tree structure has been
explored enough to ensure that the returned list is effectively the
kNN ones (obvious, but an R-Tree is a quite tricky structure, so, not
so easy to ensure :) ) the algorithm finishes.
So, I don't know if anyone is really interested with that piece of
code, but, just in case, because it may avoid some hours of hard
work. Anyway if someone wants to use it, it's pretty sure that i'll
give some help. I didn't do that by myself, but i'd be happy to work
with someone.
Nicolas.
[1] not sure, but i think that it is this one : http://
citeseer.ist.psu.edu/hjaltason98incremental.html
