[postgis-users] Automatic Geometry_columns
Paul Ramsey
pramsey at refractions.net
Fri Apr 27 11:41:05 PDT 2007
We had an interesting thought about a new approach to keeping
geometry_columns up-to-date.
probe_geometry_columns needs a little work, so upgrade that, rework it
in C, add support for views and a few other things, so that running it
is basically a magic refresh of geometry_columns to the current state of
the data base.
THEN, bind the function into the ANALYZE routine. Every time ANALYZE
gets run, update geometry columns. That way (a) in an autovacuum
situation (more and more normal) geometry_columns will tend towards
correctness over time and (b) users can update the table with one small
command, which is helpful to run anyways.
Paul
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
