[postgis-users] Again: ERROR: function 60821C60 returned NULL
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Mon Aug 6 10:09:55 PDT 2007
I am experiencing an error that I have seen in the archives with the
title: "ERROR: function 60821C60 returned NULL". Any help would be
appreciated.
It seems that in the previous posts, a null geometry (or rather too many
of them) was the cause. I, however, am experiencing it with NO NULL
geoms, instead using points with lat/lon = 0.0. That said, I have tried
it several ways, one of which is with no nulls (usigng 0.0s), the others
with the nulls. All throw the error when trying to create a GIST index.
My Data:
creating points from DD lat/lon values, with the following:
set the_geom = GeomFromText('POINT(' || "LAT_DEC" || ' ' || "LONG_DEC"
|| ')', 4326)
where "LAT_DEC" is not null and "LAT_DEC" <> 0 and "LONG_DEC" is not
null and "LONG_DEC" <> 0;
Insuring that I have no null values with the following:
update water_use_dd set the_geom = GeomFromText('POINT(0.0 0.0)', 4326)
where the_geom is null;
My system:
Output of postgis_version():
"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
PostgreSQL 8.2
Windows XP
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
Web-Based Water Supply Planning Demo:
http://soulswimmer.dynalias.net/models/wsdemo/demo_hsi.php
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070806/510ed804/attachment.html>
