[postgis-users] howto register an existing column into geometry_columns
Horacio Samaniego
horacio.samaniego at gmail.com
Mon Aug 6 16:17:17 PDT 2007
I have been trying to understand exactly how this works...
How to register an existing geometry column into geometry_columns so that
its accessible for geoprocessing.
I've unsuccessfully INSERTed the corresponding info by hand into the
geometry_columns.
The problem is the following:
I have successfully loaded two tables that I have also successfully
INTERSECTed using the && operator. Now thise has left me with a new table
where I have 2 geometry columns. The question is how do I register these
columns to the geometry_columns table so that I can see it through some
other app like QGis? I believe that some function similar to
addgeometrycolumns() should do this... but this does not update the
geometry_column... !?
here's an exerpt of by *new* table which I am unable to access with qgis
Table "public.roads_in_urban_or"
Column | Type | Modifiers
intersect_geometry | geometry |
ogc_fid | integer |
wkb_geometry | geometry |
I apologize beforehand if this is a naive question, but it wont hurt to
document this in more depth as this is probably a very common issue...
thank,
Horacio Samaniego
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070806/17d14b9a/attachment.html>
