[postgis-users] SQL Help selecting intersections
Rodrigo Martín LÓPEZ GREGORIO
rodrigomartin at lopezgregorio.com.ar
Wed Aug 8 11:59:38 PDT 2007
Hi Rob.
You can make something like this:
SELECT *, Centroid(Intersection(road1.the_geom,road2.the_geom)) AS
intersectionPoint FROM
(SELECT * FROM roads WHERE name LIKE 'Township Road 524') AS road1
JOIN
(SELECT * FROM roads WHERE name LIKE 'Range Road 20') AS road2
ON
road1.the_geom && road2.the_geom AND Intersects(road1.the_geom,
road2.the_geom)
Obviously you can select just the columns you want o get extra info like X
and Y coordinates of the intersectionPoint doing something like:
SELECT *, X(Centroid(Intersection(road1.the_geom,road2.the_geom))) AS
xcoord, Y(Centroid(Intersection(road1.the_geom,road2.the_geom))) AS Ycoord
FROM
JOIN
ON
road2.the_geom)
You can also modify the WHERE condition in the search of each individual
road like using ILIKE instead of LIKE to make the search case insensitive,
use % in the LIKE condition to search with just part of the road name, etc.
(This is just a simple solution, you can get better results doing more
complex things like having a separated table with road names and road id,
making the search in this table and getting the ids of the matched roads and
then, having a index on your road table by road_id, accessing just the roads
that have matched the previous search, etc.)
If you have any question, ask me again.
Rodrigo.
On 8/8/07, Rob McCulley <RMcCulley at county24.com> wrote:
> Hi there,
> I'm looking for a little help with some SQL. I've got a table of roads
> with names. I need to be able to get the intersection of two roads given
> the two names of the roads. The problem I have is, most of my roads have
> multiple segments with the same name.
> Currently I'm doing this in essentially three steps. For example, lets
> say I'm looking for the intersection of Township Road 524 and Range Road
> 20. I just took a look at my database, and there are two segments for Twp
> Rd 524 and there are 5 segments for Rge Rd 20. My current solution is:
> Step 1: Select all segments of Twp Rd 524.
> Step 2: Iterate through each segment of Twp Rd 524 and select any segment
> of Rge Rd 20 that intersects it. After I'm finished the iteration, I have
> two geometries that intersect, one from Twp Rd 524 and one from Rge Rd 20.
> Step 3: Select the intersection of the two geometries to get a point
> geometry.
> This seems like a bit of a brute force method of doing things. In the
> example case, I end up making four separate queries to the database. In
> some cases it could be quite a few more. I'm sure there is a more elegant
> solution, but I can't quite get my head around how to do it. Is it possible
> to get the intersection of the roads given the names in a single SQL
> statement?
> Thank You,
> Rob McCulley
> County of Vermilion River
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070808/7e466458/attachment.html>
