[postgis-users] TopologyException: no outgoing dirEdge found
Frank Koormann
frank.koormann at intevation.de
Thu Aug 9 00:25:20 PDT 2007
Moin,
[Repost to postgis-users for the records]
* Andreas Laggner <bloediandi at web.de> [070809 09:03]:
> i had the same idea and the downloads for the geos3 were already done -
> with the suggestion from Frank (thanks a lot to you) i installed the new
> version immediately. The region of LK Gifhorn were intersected WITHOUT
> errors than!! Now i have to improve the performance: Gifhorn takes 19
> seconds in ArcGis and 6 Minutes with PostGis. The intersection InVeKos
> with Atkis all over lower saxony (niedersachsen) runs since 14 hours
> now!!! That??s overkill. Does someone know how to make PostGis faster in
> GIS functions?
>From your earlier post I cannot see that you are using indexes on the
geometry columns:
- You should have indexes on your geometry columns in teh source table.
- You explicitely have to use them by including a bounding box operation
into your queries, e.g.
insert into intersect_gf2
select t1.gid,intersection(t1.the_geom, t2.the_geom)
from gf_buk t1, gf_veg2 t2
where t1.the_geom && t2.the_geom;
This reduces the set of geometries to be processed by the (expensive)
intersection, geomunion, ... to a reasonable amount.
Regards,
Frank
Frank Koormann | ++49-541-335 08 30 | http://www.intevation.de/
Intevation GmbH, Georgstr. 4, 49074 Osnabrück, DE | AG Osnabrück, HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
PostGIS Support (http://www.intevation.de/geospatial/postgis-support.de.html)
