[postgis-users] shp2pgsql problem with very large .shp-files
Stefan Zweig
stefanzweig1881 at web.de
Wed Aug 15 00:51:06 PDT 2007
hi list,
i have a problem with the shp2pgsql program:
this command:
/usr/local/pgsql/bin/shp2pgsql -s 4326 -c -I -D -k /var/gisapp/postgreexport/_G342.shp public._g342 > /var/gisapp/postgreexport/_g342.sql
works alright, no problems at all
whereas this command:
/usr/local/pgsql/bin/shp2pgsql -s 4326 -c -I -D -k /var/gisapp/postgreexport/_G2681.shp public._g2681 > /var/gisapp/postgreexport/_g2681.sql
causes shp2pgsql to answer:
"/var/gisapp/postgreexport/_G2681.shp: shape (.shp) or index files (.shx) can not be opened."
ls -la in /var/gisapp/postgreexport/ says the following:
-rwxrwxrwx 1 root root 171848556 2007-08-14 18:38 _G2681.dbf
-rwxrwxrwx 1 root root 143 2007-08-14 18:38 _G2681.prj
-rwxrwxrwx 1 root root 4565523268 2007-08-14 18:38 _G2681.shp
-rwxrwxrwx 1 root root 124980820 2007-08-14 18:38 _G2681.shx
-rwxrwxrwx 1 root root 308 2007-08-15 09:35 _G342.dbf
-rwxrwxrwx 1 root root 143 2007-08-15 09:35 _G342.prj
-rwxrwxrwx 1 root root 716 2007-08-15 09:35 _G342.shp
-rwxrwxrwx 1 root root 276 2007-08-15 09:35 _G342.shx
so the only difference between shp-file _g2681 and shp-file _g342 is that _g2681 is an extremely big one. (and actually there is another difference: _G342.shp is a point shape, _g2681.shp is a line shape)
any ideas?
i appreciate any help, thanks in advance,
stefan
______________________________________________________________________________
Jetzt neu! Im riesigen WEB.DE Club SmartDrive Dateien freigeben und mit
Freunden teilen! http://www.freemail.web.de/club/smartdrive_ttc.htm/?mc=021134
