[postgis-users] Extracting a line from multilinestring
Rodrigo Martín LÓPEZ GREGORIO
rodrigomartin at lopezgregorio.com.ar
Wed Aug 15 17:43:40 PDT 2007
Hi Brian...
I think you can do one of this things:
1. If you are sure that all your geometries have just one LINESTRING then
you can do:
SELECT
line_interpolate_point(GeometryN(the_geom,1),line_locate_point(GeometryN(the_geom,1),PointFromText('POINT(-
74.5 40)'))) FROM roads ORDER BY Distance(the_geom,PointFromText('POINT(-
74.5 40)')) LIMIT 1
2. If your geometries have more than one LINESTRING but this LINESTRINGS are
continuous (i.e. there are no gaps between the LINESTRINGS in a
MULTILINESTRING) you can use:
SELECT
line_interpolate_point(LineMerge(the_geom),line_locate_point(LineMerge(the_geom),PointFromText('POINT(-
74.5 40)')) LIMIT 1
If you want to verify if all your geometries have just one LINESTRING you
can try:
SELECT count(*) FROM roads WHERE NumGeometries(the_geom) > 1
This will return the number of MULTILINESTRINGS that have more than one
LINESTRING
Rodrigo
On 8/15/07, Peck, Brian <brian.peck at lmco.com> wrote:
> Hey all,
> Does anyone if there is a way to extract a line from a MultiLineString?
> I am trying to make the call
> SELECT
> line_interpolate_point(the_geom,line_locate_point(the_geom,PointFromText('POINT(-
> 74.5 40)')) LIMIT 1
> But I get the error
> ERROR: line_locate_point: 1st arg isn't a line
> My 'the_geom' field is filed with MultiLineString data (though only
> LineString in each one).
> Ex:
> select AsText(the_geom) from roads limit 1;
> astext
> MULTILINESTRING((-74.4595680236816 40.0301723480225,-74.4591522216797
> 40.0302429199219))
> (1 row)
> - Brian Peck
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070815/a4ba31bc/attachment.html>
