[postgis-users] Query for nearest linestrings to a point, for latitude/longitude
Ovidiu Gheorghies govidiu at yahoo.com
Fri Aug 17 02:17:13 PDT 2007
Hello all,
I'm writing to ask if at this moment there is a better approach to what I am trying to achieve in PostGIS.
The purpose of the query is to determine all the linestrings within x
km from a point, given that the linestrings and the point are stored as
GPS positions (latitude/longitude, SRID=4326).
(see attached image)
My proposed algorithm is:
    * step 1: select all the linestrings within, say, 1 degree of latitude/longitude from the given point P, located at POINT(44 15):
 SELECT myline, myname
   FROM mylines
     WHERE myline && Expand('POINT(44 15)', 1)
The purpose is to quickly select relevant linestrings, using an index. For example, in the figure, lines L1, L2 and L3 will be selected, while L4 and other far-away linestrings will not be selected.
    * step 2: for each of the obtained lines (L1, L2, and L3 in the figure) determine the closest points/projections (P1, P2 and P3) on the corresponding linestrings using (in pseudo-code):
Pi_factor := line_locate_point(Li, P)
Pi := line_interpolate_point(Li, Pi_factor)
    * step 3: for each of the determined points (P1, P2, P3), compute the distance to P:
Di := distance_sphere(P, Pi)
    * step 4: knowing the correct distances on Earth between the points, select the desired linestrings
I'd love to hear that this can be done much easier in PostGIS, but if not I will contribute a working plpgsql function based on your feedback.
Best regards,
Ovidiu
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070817/386bff42/attachment.png>
