[postgis-users] PostGIS supresses the "LIMIT"
Michael Smedberg
Michael.Smedberg at redfin.com
Fri Aug 17 16:59:30 PDT 2007
Mark,
Thanks for the reply!
Yup, adding that WHERE clause DOES make a big difference, but not big enough (in a sense.) It doesn’t really explain the performance difference (it still seems like maybe the LIMIT is not optimized by PostGIS?):
Adding a WHERE clause to the simple SELECT query which causes it to return EXACTLY the same number of rows causes it to be executed in about 1 second. Note that this is filtering on a column that is NOT indexed:
# explain analyze select search_id from property_search_keys where search_id <= 699148 limit 1;
QUERY PLAN
Limit (cost=0.00..1.01 rows=1 width=4) (actual time=1091.551..1091.552 rows=1 loops=1)
-> Seq Scan on property_search_keys (cost=0.00..711933.16 rows=701567 width=4) (actual time=1091.537..1091.537 rows=1 loops=1)
Filter: (search_id <= 699148)
Total runtime: 1091.579 ms
(4 rows)
In comparison, doing a similar query against the same table, but LIMITing on a GIS indexed column (which returns the same number of rows) takes about 12 seconds:
# GeomFromText('Polygon((47.339753313135965
# -122.96722412109376,47.339753313135965
# -121.63375854492188,47.877670790949324
# -122.96722412109376,47.339753313135965 -122.96722412109376))', 4269) &&
# centroid limit 1;
QUERY PLAN
Limit (cost=0.00..1.67 rows=1 width=4) (actual time=11426.844..11426.845 rows=1 loops=1)
-> Seq Scan on property_search_keys (cost=0.00..711933.16 rows=425818 width=4) (actual time=11426.841..11426.841 rows=1 loops=1)
Filter: ('0103000020AD100000010000000500000035505C097DAB474001000000E7BD5EC035505C097DAB4740000000808F685EC012E4378457F04740000000808F685EC012E4378457F0474001000000E7BD5EC035505C097DAB474001000000E7BD5EC0'::geometry && centroid)
Total runtime: 11426.865 ms
(4 rows)
Note that they both return the same number of rows:
# select count(*) from property_search_keys where search_id <= 699148;
count
699148
# centroid;
count
699148
And they’re both a relatively small fraction of the table:
# select count(*) from property_search_keys;
count
11507213
Message: 3
Date: Thu, 16 Aug 2007 23:28:10 +0100
From: Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk>
Subject: Re: [postgis-users] PostGIS supresses the "LIMIT"
optimization?
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID: <1187303290.5711.3.camel at mca-desktop>
Content-Type: text/plain; charset=utf-8
On Thu, 2007-08-16 at 10:52 -0700, Michael Smedberg wrote:
> I believe that Postgres has an optimization that “short-circuits†plan
> execution when the SQL contains a LIMIT clause, but no “order by†or
> other function that requires the whole result set. It seems like
> PostGIS turns this optimization off (I’m using PostGIS 1.2.1.) Is
> this a known bug? Is there a workaround that would allow me to have
> poorly constrained GIS queries return quickly (if it’s poorly
> constrained, I don’t care about the results, I just want to know that
> there are too many to display)? In other words, is there a way for me
> to KNOW it’s poorly constrained without having to wait for the whole
> (large) result set to be generated?
(cut)
> I’m a newbie to this list, so please forgive me if this is a dumb
> question…
No, it's actually a good question :)
The first thing to notice is that your queries are different because
your second query has a WHERE clause - does your first query behave any
differently with a WHERE clause added? Make sure you choose a condition
that selects a similar percentage of the table as a good test.
HTH,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk <http://www.ilande.co.uk/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070817/ab43813c/attachment.html>
