[postgis-users] Mac OS X regression failures - 13/35 (was no "coveredby" in liblwgeom.1.3.so")
Webb Sprague webb.sprague at gmail.com
Wed Aug 22 10:35:16 PDT 2007
Here is my log file and a rerun of the regression.  Cheers, and let me
know if there is anything else.
Here is your request (seems to me that these should fail, but the
regression test isn't checking for that correctly - maybe a mac thing
or a funny version of sed or something?).  I don't see any server
crashes at all:
> select '50', 'POINT()'::GEOMETRY as geom;
snip
> Could you try executing these one at a time from psql and let me know the results?
oregon_2007_08_20=# set search_path=public,postgis;
SET
oregon_2007_08_20=# select postgis_full_version();
 POSTGIS="1.3.2" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22 Oct
2006" USE_STATS
(1 row)
oregon_2007_08_20=# select '50', 'POINT()'::GEOMETRY as geom;
ERROR:  parse error - invalid geometry
oregon_2007_08_20=# select '51', 'POINT(1)'::GEOMETRY as geom;
oregon_2007_08_20=# select '52', 'POINT(,)'::GEOMETRY as geom;
oregon_2007_08_20=# select '53', 'MULTIPOINT(,)'::GEOMETRY as geom;
oregon_2007_08_20=# select '54', 'POINT(a b)'::GEOMETRY as geom;
oregon_2007_08_20=# select '55', 'MULTIPOINT()'::GEOMETRY as geom;
oregon_2007_08_20=# select '56', ST_asewkt('POLYGON( (0 0, 10 0, 10
10, 0 10) )'::GEOMETRY);
ERROR:  geometry contains non-closed rings
oregon_2007_08_20=# select '57', ST_asewkt('POLYGON( (0 0, 10 0, 10
10, 0 10, 0 0),(5 5, 7 5, 7 7 , 5 7) )'::GEOMETRY);
oregon_2007_08_20=# select '58', ST_asewkt('MULTILINESTRING((0 0, 1
1),(0 0, 1 1, 2 2,) )'::GEOMETRY);
10, 0 10) )'::GEOMETRY);ERROR:  geometry contains non-closed rings
oregon_2007_08_20=# select '56', ST_asewkt('POINT( 0 10)'::GEOMETRY);
 ?column? |  st_asewkt
 56       | POINT(0 10)
(1 row)
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070822/0589585f/attachment.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070822/0589585f/attachment-0001.bin>
