[postgis-users] Analyse and erase the intersecting part of polygons
Andreas Laggner
andreas.laggner at fal.de
Thu Aug 23 06:41:51 PDT 2007
Hello postgis-users,
i did an "append" of many geometries by inserting 70 tables in one table
like this:
create table Atkisvegd(atkis_id integer, land character varying(2), oba
integer) with oids;
select
addgeometrycolumn('','atkisvegd','the_geom','31467','MULTIPOLYGON',2);
insert into Atkisvegd select gid, land, oba, the_geom from hh_veg1;
insert into Atkisvegd select gid, land, oba, the_geom from hh_veg2;
insert into Atkisvegd select gid, land, oba, the_geom from hh_veg3;
insert into Atkisvegd select gid, land, oba, the_geom from hh_veg4;
insert into Atkisvegd select gid, land, oba, the_geom from hh_veg5;
insert into Atkisvegd select gid, land, oba, the_geom from mv_veg1;
insert into Atkisvegd select gid, land, oba, the_geom from mv_veg2;
insert into Atkisvegd select gid, land, oba, the_geom from mv_veg3;
insert into Atkisvegd select gid, land, oba, the_geom from mv_veg4;
insert into Atkisvegd select gid, land, oba, the_geom from mv_veg5;
and so on..........
there should not exist any intersections, but actually there are
intersections! (about 0.6% of the total area).
My AIM:
I want to eliminate the wrong part of the overlapping polygons (what´s
wrong i can analyse with the attributes!).
For example i have many Polygons that are declared as "wet soils" and
these often overlaps with other landuse
(98.7% of the overlapping area is "wet soils"). I derived this
informations from the dataset in ArcGis.
adios Andreas
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
