[postgis-users] Union of 7 datasets
Obe, Regina
robe.dnd at cityofboston.gov
Thu Aug 23 07:53:38 PDT 2007
Oh the g1 g2 .. was just for example - I don't actually call my tables meaningless names like that.
You should be doing a join on something or have a where clause unless one of your tables has only one record. Otherwise you are doing what is called a CROSS JOIN (cartesian product) which gives you an nxm records where n is the number of records in your first table and m is the number in second table. This is generally a big NO NO. In certain rare cases you do want to do something like that, but is usually the exception.
Its hard for me to tell if you need a cartesian product in this case since I'm not quite sure what for example nature and biosphere represent. I would guess that is wrong and you should first figure out which sets of say nature records you need to geomunion with biosphere and then join by that field or set of fields.
It would help a bit if you could provide some sample questions you expect to answer with your statistical analysis. My guess is you may be better off with more than one table.
Which structure is best really boils down to what questions you hope to answer because one approach may make one question easy and fast and another question slow and cumbersome.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas Laggner
Sent: Thursday, August 23, 2007 10:04 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Union of 7 datasets
Obe, Regina schrieb:
> Andreas,
> It would help to know what your table structure looks like and why do you want to put them all in a single geometry?
My table structures are a little bit different. I want to have them in a
single geometry to intersect them with other data and built a large
table to run statistics over it (production site analysis over germany).
> I'm imaging you are you doing something like
> SELECT g1.somefield, geomunion(geomunion(g1.the_geom, g2.the_geom), g3.the_geom)
> FROM g1 INNER JOIN g2 on g1.somefield = g2.somefield INNER JOIN g3 on g2.somefield = g3.somefield
> GROUP BY g1.somefield
That´s an interesting method with inner join..why go you call your
tables g1. g2. and so on?
That´s my method i am using right now (geomunion 1 to 3 from 6), seems
to be a pedestrian method :-(
create table natura2000
(ffh_name character varying(80), ffh_land character varying(3), ffh
smallint, ffh_id smallint,
spa_name character varying(80), spa_land character varying(3), spa
smallint, spa_id smallint) with oids;
select
addgeometrycolumn('','natura2000','the_geom','31467','MULTIPOLYGON',2);
alter table natura2000 drop constraint enforce_geotype_the_geom;
insert into natura2000
select
t1.ffh_name,t1.ffh_land,t1.ffh,t1.ffh_id,t2.spa_name,t2.spa_land,t2.spa,t2.spa_id,
geomunion(t1.the_geom, t2.the_geom)
from ffh_rep t1, spa_rep t2;
create table sg71
smallint, spa_id smallint,
bio_name character varying(70), bio smallint, bio_id smallint) with
oids;
select addgeometrycolumn('','sg71','the_geom','31467','MULTIPOLYGON',2);
alter table sg71 drop constraint enforce_geotype_the_geom;
insert into sg71
select t1.ffh_name, t1.ffh_land, t1.ffh, t1.ffh_id, t1.spa_name,
t1.spa_land, t1.spa, t1.spa_id,
t2.name,t2.bio,t2.bio_id,geomunion(t1.the_geom, t2.the_geom)
from natura2000 t1, biosphere t2;
create table sg72
ffh smallint, ffh_id smallint,
bio_name character varying(70), bio smallint, bio_id smallint,
np_name character varying(60), np smallint, np_id smallint) with oids;
select addgeometrycolumn('','sg72','the_geom','31467','MULTIPOLYGON',2);
alter table sg72 drop constraint enforce_geotype_the_geom;
insert into sg72
t1.bio_name,t1.bio,t1.bio_id,t2.np_name,t2.np,t2.np_id,
from sg71 t1, np t2;
AND SO ON......
> or
> SELECT g1.somefield, geomunion(gt.the_geom)
> FROM (SELECT somefield, the_geom FROM g1 UNION SELECT somefield, the_geom FROM g2 ...) gt
> GROUP BY gt.somefield
> If I have 7 different tables that have pretty much the same structure, but for logistical or other technical reasons (such as each has additional attributes distinct from one another), I need to keep them as separate tables, then I usually use inherited tables for that. That way when I need to join all datasets at once, I can simply query the parent table and it will automatically drill down to the child tables. Not sure if that helps more than it confuses your situation.
> Then instead of the above I can simply do
> SELEG myparenttable.somefield, geomunion(myparenttable.the_geom)
> FROM myparenttable
> GROUP by gh.somefield
ok - i have to think about your suggestions......that´s my second week
with postgis.
Can you tell me from my SQL-Statements which method will be best? So i
try to understand that one.....
Thanks for your reply!!!
> Hope that helps,
> Regina
> Sent: Thursday, August 23, 2007 9:11 AM
> To: PostGis_Mailinglist
> Subject: [postgis-users] Union of 7 datasets
> Hi users,
> i want to put together 7 datasets to have all the different refuges in
> one table (and in one geometry). Am i doing right with 6 times geomunion
> (that´s much to type with all the attributes) or is there a more
> effective way?
> cheers Andreas
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
