[postgis-users] Query Help
Obe, Regina
robe.dnd at cityofboston.gov
Fri Aug 24 08:12:06 PDT 2007
IF you use a subselect, you really don't need the from polygons piece
you have there. I think you can simply write
UPDATE lines
SET pname = (select a.name
FROM polygons a
WHERE a.the_geom &&
expand(lines.the_geom, 0.1)
ORDER BY distance(a.the_geom,
lines.the_geom) asc
LIMIT 1)
WHERE lines.pname = ''
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Stephen Woodbridge
Sent: Friday, August 24, 2007 10:55 AM
To: PostGIS Users Discussion
Subject: [postgis-users] Query Help
I have tables "polygons" (100s rows) and "lines" (~2mil rows) and a few
(~150 rows) of the "lines" fall outside any polygon. I would like to
update the lines.pname and assign the polygons.name where the
polygons.name is the closest polygon to the line and pname=''. But I
can't quite figure out the query so I only assign the closest one:
update lines set pname=a.name
from polygons a
where lines.pname=''
and ...
I think I need to make "a.name" into a subselect so it selects the
closest polygon for each row, something like:
(select a.name
where a.the_geom && expand(lines.the_geom, 0.1)
order by distance(a.the_geom, lines.the_geom) asc
limit 1)
But I'm not sure how to set up the subselect, that references columns
from the update.
Any suggestions on this one would be appreciated.
-Steve
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
