[postgis-users] Geometry Functions?
chris hinkle lilhinx at gmail.com
Mon Aug 27 14:20:44 PDT 2007
I think the problem is simpler than that, select postgis_full_version();
gives the same error.
Is there a step I'm missing to initialize the db with the functions?
On 27/08/07, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> To add you should check which version you have installed
> By running the following
> If it returns something lower than 1.2.2 then you should use the names
> without the ST in front of them.
> I developed 2 cheatsheets.
> One is for 1.2.1
> http://www..bostongis.com/postgis_quickguide_1_2_1.bqg<http://www.bostongis.com/postgis_quickguide_1_2_1.bqg>
> and one is for 1.3.1
> http://www.bostongis.com/postgis_quickguide.bqg
> I'm still fleshing out the examples and gaps in both.  Hopefully these
> will be of benefit to you.
> Thanks,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Milo van der
> Linden
> *Sent:* Monday, August 27, 2007 4:19 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Geometry Functions?
> Hello Chris,
> Welcome!
> Try calling them without the ST_ in front of it:
> SELECT transform(simplify(transform(the_geom, 2249), 500),4326) from
> neighborhoods
> As described on:
> http://www.bostongis.com/postgis_simplify.snippet
> Good luck!
> chris hinkle schreef:
> Hi, very new to this, but I'm trying to call functions like ST_Simplify
> and I'm getting errors telling me that the function doesn't exist.
> I installed Postgres and PostGIS using the binary windows installers.
> What did I miss?
> Chris Hinkle
> Brooklyn, NY
> 646-240-3024
> postgis-users mailing list
> postgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
>  Milo van der Linden
> skype: milovanderlinden
> mlinden at zeelandnet.nl
> milovanderlinden at gmail.com
> milo at 3dsite.nl
> http://www.3dsite.nl
> De informatie in dit bericht reflecteert mijn persoonlijke mening en niet
> die van een bedrijf of instantie. Aan de informatie kunnen geen rechten
> worden ontleend. Indien dit bericht onderdeel is van een forum, mailing-list
> of community dan gelden automatisch de bij het betreffende medium behorende
> voorwaarden. The information in this message reflects my personal opinion
> and not that of a company or public body. All rights reserved.If this
> message is contained in a mailing-list or community, the rights on the
> medium are automatically adapted.
> * The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer. *
Chris Hinkle
Brooklyn, NY
646-240-3024
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070827/c8455e26/attachment.html>
