[postgis-users] Building PostGis with VC++
Charlie Savage
cfis at savagexi.com
Tue Aug 28 18:59:21 PDT 2007
> Could you specify what version of Visual C++ you're using?
> Just for clarification.
VC++ 2005.
> Possible workaround is to compile .c file in C++ mode (use /TP instead
> of /TC option).
I suppose, but why not just fix it. If I remember correctly, it
happened only a couple times in the new files for supporting curved
geometry. They were very simple changes.
>> * VC++ thought MAX_FLOAT was too big (3.40282347e+38F versus
>> 3.402823466e+38F)
> Hmm, could you point where this constant is used?
Ah, sorry, got the name slightly wrong. See lwcurve.c, line 24
#ifndef MAXFLOAT
#define MAXFLOAT 3.40282347e+38F
#endif
According to VC++ that's too big. Which leads to an interesting
question as to why GCC doesn't think so.
>> * The method createTree must use some GCC magic to initialize a variable
>> sized array:
>> RTREE_NODE *nodes[pointArray->npoints];
>> That has to be done via malloc/free on Windows.
> Visual C++ does not support VLA, so this code is well unsupported by
> Microsoft's compiler.
Right - but easy enough to dynamically allocate the array using
malloc/free (well I guess palloc) like in other places in PostGis - its
just 2 lines more of code.
> Simply, Visual C++ does not support features from addendum to the C
> language standard, but only plain C89.
Yup. And of course other people have had the same issues so its easy to
find workarounds.
> Perhaps, pj_errno could be replaced with function pointers, as it errno
> global is solved in newer and thread-safe implementations of C library.
> extern int* pj_errno_proxy(void);
> #define errno (*pj_errno_proxy())
Either this way or just having a simple function that returns the value.
Depends if you want an event like interface or not.
> p.s. i've taken the liberty to give my 5 cents :-)
Thanks for the thoughts. Should I send a patch along for review?
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070828/a6aea9ba/attachment.bin>
