[postgis-users] connection terminated with buffer(0.0)
Andreas Laggner
andreas.laggner at fal.de
Wed Aug 29 07:41:23 PDT 2007
Moin Stefan,
i am running the buffer (0.0) to repair invalid polygons, for sure i
have invalid polygons than ;-)
But all of them are SIMPLE, all are CLOSED and none is EMPTY. With
ISRING i get back an error:
ERROR: isring() should only be called on a LINE
And that?s curious - because i should not have linestring in that
dataset.....
I could not find out what your solution was. To built the test table and
see which polygon causes the error? But that did not work, because my
SQL-Version is doing an automatic rollback if the operation is not
finished regulary.
So....what to do?
Cheers Andreas
Stefan Zweig schrieb:
> hi andreas,
> recently i had a similar problem. i figured out, that the actual reason was that the buffer(the_geom,0) function seems to crash on polygons which are not closed, i.e. first point != last point, even if only one polygon or one part of a multipolygon is such a not closed on. so it might help you to check whether all the polygons are closed / valid in this the_geom column.
> stefan
> refer to my postings from august to
> An I/O error occured while sending to the backend
> and
> how to polygonize a not closed linestring?
>> -----Ursprüngliche Nachricht-----
>> Von: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>> Gesendet: 28.08.07 17:17:11
>> An: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>> Betreff: Re: [postgis-users] connection terminated with buffer(0.0)
>> Figure out which geometry is the problem one so (a) you can work
>> around it and (b) you can attach it to a bug report and (c) we can
>> eventually fix it.
>> Worst case scenario, binary search by repeatedly cutting your input
>> data set in half.
>> P
>> On 28-Aug-07, at 5:16 AM, Andreas Laggner wrote:
>>> Hello,
>>> i used buffer(the_geom, 0.0) several times to repair geometry and
>>> it works good. But now i have a dataset, where problems occur: Any
>>> time i try to repair with buffer the connection to postgresql is
>>> terminated. It seems to relate to one (or more) bad geometry. What
>>> can i do now?
>>> My statement (the most simple one without attributes to minimize
>>> possible sources for errors):
>>> create table gemeinden_rep();
>>> select addgeometrycolumn
>>> ('','gemeinden_rep','the_geom','31467','MULTIPOLYGON',2);
>>> alter table gemeinden_rep drop constraint enforce_geotype_the_geom;
>>> insert into gemeinden_rep
>>> select buffer(the_geom, 0.0)
>>> from gemeinden;
>>> Thanks Andreas
>>> Dipl. Geoökologe Andreas Laggner
>>> Institut für Ländliche Räume (LR)
>>> Bundesforschungsanstalt für Landwirtschaft (FAL)
>>> Institute of Rural Studies
>>> Federal Agricultural Research Centre (FAL)
>>> Bundesallee 50
>>> D-38116 Braunschweig
>>> Tel.: (+49) (0)531 596 5515
>>> Fax: (+49) (0)531 596 5599
>>> E-mail: andreas.laggner at fal.de
>>> Homepage: http://www.lr.fal.de/
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> _________________________________________________________________________
> In 5 Schritten zur eigenen Homepage. Jetzt Domain sichern und gestalten!
> Nur 3,99 EUR/Monat! http://www.maildomain.web.de/?mc=021114
Bundesallee 50
