AW: [postgis-users] Geomunion
Andreas Laggner andreas.laggner at fal.de
Thu Aug 30 04:57:11 PDT 2007
Hi Thorsten,
do you want to perform a dissolve (you put geometries from many rows in
one row) or what do want to achieve?
with geomunion you can do very different things!!!!
cheers      Andreas
Thorsten Kraus schrieb:
> OK, I found a solution:
> SELECT multi(geomunion(geom)) from table1.
> Now I want to use this query to get the number of holes in the union
> of all geometries:
> SELECT NumInteriorRings(multi(geomunion(geom))) FROM table1
> This queries perform very very bad. I cancelled a query on a table
> with about 10000 geometries because it takes over an hour without
> being completed. Is there a better way to union such a big number of
> geometries?
>  -----Ursprüngliche Nachricht-----
> *Von:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]*Im Auftrag von
> *Thorsten Kraus
> *Gesendet:* Donnerstag, 30. August 2007 12:54
> *An:* PostGisMailingList (E-Mail)
> *Betreff:* [postgis-users] Geomunion
>     Hello,
>     I want to union all geometries of a table into one big geometry.
>     Do you know how this task can be performed the best way?
>     Regards,
>     Thorsten
> postgis-users mailing list
Dipl. Geoökologe Andreas Laggner
Institut für Ländliche Räume (LR)
Bundesforschungsanstalt für Landwirtschaft (FAL)
Institute of Rural Studies
Federal Agricultural Research Centre (FAL)
Bundesallee 50
D-38116 Braunschweig
Tel.: (+49) (0)531 596 5515
Fax: (+49) (0)531 596 5599
E-mail: andreas.laggner at fal.de
Homepage: http://www.lr.fal.de/
