[postgis-users] Can ArcView view the maps stored in postGIStables?
James Stott James.Stott at npaconsult.co.uk
Tue Dec 4 03:13:04 PST 2007
http://www.npaconsult.co.uk/
Thanks for the suggestion Per-Olof. This is fine if I want to export things but I was thinking more along the lines of a solution that allows you to view your data within MapInfo straight from the postigs database instead of having to convert the data into tab and then view it.
Thanks,
James
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Per-Olof Norén
Sent: 30 November 2007 11:14
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Can ArcView view the maps stored in postGIStables?
James Stott skrev:
> While the subject is on getting postgis data into GIS packages, does
> anyone know of a solution to get postgis data into MapInfo?
> I have looked at using FME in conjunction with the open universal data
> option that is available in MapInfo 9 but wondered if there was a
> solution that didn't involve purchasing FME?
Maybe exporting as shp using psql2shp and then using ogr2ogr to convert
into .TAB?
Cheers,
Per-Olof
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
Environmental Planners - Landscape Architects - Ecologists
30 Brock Street, Bath, BA1 2LN
Tel: +44 (0) 1225 445548 Fax: +44 (0) 1225 312387
