[postgis-users] intersection/within queries - newbie basic spatial queries
Josh Livni josh at umbrellaconsulting.com
Thu Dec 6 22:26:47 PST 2007
Craigie,
Not 100% sure I parsed your question right.  It's possible others may
also be confused.  You say 'all the polys in sec_catch fall within a
single record of prim_catch' .. are you then wondering which polygon of
sec_1 it is that they all fall within?
Or maybe, what you're trying to accomplish is to get, for each polygon
in the prim_catch table, a list of all polygons from sec_catch that are
inside that prim_catch polygon.... ?
On the other hand, I may be misunderstanding something obvious, in which
case I am sure others will be able to assist without further translation.
Cheers,
  -Josh
Craigie Dirk wrote:
> I am a new user and trying to perform some basic spatial queries using
> within/intersect/union etc.
> I have 2 x polygon files :
> Prim_catch (19 x records)
> Sec_catch (attribute secondary = text field name of catchment)
> All the polys in sec_catch fall within a single record (polygon) of
> prim_catch
> The query I am using (see below) needs some kind of loop or temporary
> table as it returns a true/false and not a list of the records = true.
> SELECT secondary FROM sec_catch
> WHERE WITHIN((select the_geom from sec_catch),(select the_geom from
> prim_catch))
> Any help, sample will be appreciated
> Thanks,
> Dirk Craigie
> DISCLAIMER:
> This message and any attachments are confidential and intended solely
> for the addressee. If you have received this message in error, please
> notify the system manager/sender. Any unauthorized use, alteration or
> dissemination is prohibited. The Department of Water Affairs and
> Forestry further accepts no liability whatsoever for any loss, whether
> it be direct, indirect or consequential, arising from this e-mail, nor
> for any consequence of its use or storage.
> postgis-users mailing list
