[postgis-users] How do multipolygons work?
Simon Schneider
Kallas at gmx.de
Sun Dec 9 10:51:36 PST 2007
I've a table with a multigeometry geometry column with only one object
inserted:
insert into test(name, geom) values('Main',
GeomFromEWKT('MULTIPOLYGON(((0 0 0, 40 0 0, 40 50 0, 0 50 0, 0 0 0),(40
0 0, 50 0 0, 50 50 0, 40 50 0, 40 0 0)))'));
And now I wanted to check whether a certain point lies within this
multipolygon via this query:
SELECT name FROM test WHERE distance(GeomFromText('POINT(45 5)',-1),
geom)=0;
The thing I don't understand is that above query delivers no result, but
when I try a query with the point inside the first part of the
multipolygon like:
SELECT name FROM test WHERE distance(GeomFromText('POINT(20 5)',-1),
geom)=0;
it returns "Main" as expected.
Can anybody explain to me why the query doesn't return anythin wheng the
point is in the second polygon?
Cheers,
Simon
