[postgis-users] Change projection in select?
Obe, Regina robe.dnd at cityofboston.gov
Thu Dec 13 05:48:39 PST 2007
Just a name difference currently.  St_transform name was put in place to be more in line with OGC naming.  Moving forward there might be a difference as transform is deprecated and may not be improved on and will eventually be removed.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Runesson Magnus
Sent: Thursday, December 13, 2007 8:45 AM
To: PostGIS Users Discussion
Subject: SV: [postgis-users] Change projection in select?
Thanks!
What is the difference between st_transform and transform?
I notice that both are wotking for me.
Regards,
/Magnus, SMHI
-----Ursprungligt meddelande-----
Från: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] För Obe, Regina
Skickat: den 13 december 2007 14:29
Till: PostGIS Users Discussion
Ämne: RE: [postgis-users] Change projection in select?
SELECT AsText(ST_Transform(geom, 3021)) FROM mytable
If you are using a pre-1.2 install of PostGIS you may need to use
transform(geom,3021) instead of st_transform(geom,3021)
Runesson Magnus
Sent: Thursday, December 13, 2007 8:22 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Change projection in select?
I have a table where my geometries are saved in SRID 4326. To get my
result in text I do:
SELECT asText(geom) FROM myTable;
Sometimes I want to get my results from the select in 3021 instead. Can
I do that? How do I do that?
Regards,
/Magnus, SMHI
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
