[postgis-users] GiST index on Geometry Column
Kyle Wilcox
Kyle.Wilcox at noaa.gov
Thu Dec 13 10:59:33 PST 2007
I am indeed running PostGIS 1.1.6.
# select postgis_full_version();
POSTGIS="1.1.6" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006"
USE_STATS
(1 row)
# select * from pg_proc where proname='transform'
proname | pronamespace | proowner | prolang | proisagg | prosecdef |
proisstrict | proretset | provolatile | pronargs | prorettype |
proargtypes | proallargtypes | proargmodes | proargnames | prosrc |
probin | proacl
transform | 2200 | 10 | 13 | f | f |
t | f | i | 2 | 16426 | 16426
23 | | | | transform |
$libdir/liblwgeom.dll |
(1 row)
I have not attempted to upgrade in the past but I may now take the step
to get rid of the packaged PostGIS that came with Postgres and start
using the Installers from refractions website.
Mark Cave-Ayland wrote:
> On Thu, 2007-12-13 at 11:14 -0500, Kyle Wilcox wrote:
>> I am having trouble creating a GiST index on a MULTIPOLYGON column.
>> When the table is empty, the indexes will be created without errors, but
>> inserts will fail with the error. When the table has entries in it, the
>> creation of the index will fail with the same error. The index creation
>> only fails on the poly_geom column and works in both conditions for the
>> point_geom column.
>> ERROR: function 60821C60 returned NULL
>> PostgreSQL: 8.2.4 on Windows
> Hi Kyle,
> Could this be the indexing bug which caused the release of PostGIS
> 1.1.7? What does "SELECT postgis_full_version();" and "select * from
> pg_proc where proname = 'transform';" return?
> Also, have you attempted to upgrade PostGIS from 1.1.6 to 1.1.7 in the
> past?
> Kind regards,
> Mark.
Kyle Wilcox
NOAA Chesapeake Bay Office
410 Severn Avenue
Suite 107A
Annapolis, MD 21403
office: (410) 295-3151
"It is from the wellspring of our despair and the places
that we are broken that we come to repair the world."
- Murray Waas
