[postgis-users] Points-in-polygon performance
Paul Ramsey
pramsey at refractions.net
Thu Dec 20 15:00:54 PST 2007
IF # of points is very very big, then (a) below is probably very
wise, if you can get away with it.
On 20-Dec-07, at 1:48 PM, Robin Chauhan wrote:
> I have a region_polygons table where region_polygons.rpg_geom is a
> MULTIPOLYGON.
> I want to select rows in the geom_table where geom_table.geom_fld
> is within region_polygons.rpg_geom
> The following idiom works for me, but is waaaay slow (whereas I
> found other kinds of spatial queries are pretty zippy):
> SELECT * from geom_table where EXISTS
> (select rpg_id from region_polygons where
> geom_fld && rpg_geom and intersects(geom_fld,
> rpg_geom) and rpg_name='GVRD_OLD')
> Where should I start?
> a) Simplify the multipolygon?
> b) Joins instead of EXISTS?
> c) Would putting the literal WK format for the polygon right into
> the SQL query help?
> d) ... or something else?
> Robin R Chauhan
> Pathway Intelligence Inc
> robin at pathwayintelligence.com
> 604-886-3964
> postgis-users mailing list
