[postgis-users] A bit off topic, but FOSS GIS clients...
Obe, Regina
robe.dnd at cityofboston.gov
Mon Dec 31 08:37:42 PST 2007
As Frank said - this is probably more appropriate for QGIS or OSGEO
list. Anyrate I'll offer my two cetns.
What is your idea of tiny shapefiles or moderate size. From experience
loading shape files in QGIS, they seem to load fairly fast - files
around 5MB - 20 MB. Granted the filtering capabilities could be
improved. I haven't used uDig enough to comment.
Are you loading across a network or locally. I would expect if you put
the data in PostGIS and you are accessing via a network, you should
notice some improvement,but compared to local shapefiles, it will be
comparable or worse.
--Am I mistaken, or is FOSS GIS weakest when it comes to
the non-web based GIS client arena? No you are not. I think FOSS GIS is
still strongest in web based stuff. As far as GIS client stuff, it is
still behind the commercial products.
--Why don't all these clients unite?
That's a difficult question and one I have thought about myself. I think
it's a pretty multi-dimensional question.
a) As Frank has said they do unite usually on more micro levels (Which I
think is pretty neat and not as often seen in Commercial products) -
e.g. you see Geos, GDAL, JTS, Proj, OpenLayers, Grass used in numerous
disjoint projects. So when they unite its often at a very granular
level (which as a mere user you may not be privy to) which I tend to
think is way better than at a higher macro level.
b) Uniting at a macro level is often trickier and not as useful in my
opinion. At the macro level you are beginning to talk about big stoves.
To join two big stove projects into one presumes everyone wants the same
thing out of a GIS desktop client. If I were developing a java app, I
would guess integrating uDig components would be far easier than using
QGIS. If I wanted something to integrate with say MS Access or some
other activex way - MapWindow would fit nicely. If I was doing .NET
client SharpMap would be a nice fit.
From a newbie usability standpoint, I find QGIS easier to use, but
recognize that uDig has a lot of sophisticated functionality that QGIS
lacks. Not to mention QGIS is QT based and uDig is java-based. If these
were to unite, I think it would be really tricky to not alienate one
group of users and programmers.
Personally I find ESRI stuff really hard to use for doing statistical
analysis among other things so I guess I better not voice my opinions
too loudly about what I think of ESRI offerings compared to other
commercial/FOSS offerings out there.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of dnrg
Sent: Monday, December 31, 2007 10:41 AM
To: postgis postgis
Subject: [postgis-users] A bit off topic, but FOSS GIS clients...
This is off-topic. But since many use
PostGIS/PostgreSQL as a spatial database backend, I
thought people here may be best equipped to comment. I
couldn't be the only one wondering about this.
Quantum GIS is painfully slow rendering and searching
through data in moderately sized, and evidently even
tiny, shapefiles. That's *with* scale-dependent
display set to reasonable values.
Seems QGIS is a decade or more behind even ArcView 3.2
(still a great product after all these years) with
regard to performance and basic (non-OGC and web)
functionality.
Will importing the shapefiles into PostgreSQL solve
the data access speed issues? Is the rendering engine
itself problematic, or is the slowness a function of
its inability to work efficiently with shapefiles?
I find QGIS simply unusable when working with
shapefiles. Considering many GIS novices still work
with shapefiles, I'm guessing the lack of
an efficient FOSS GIS client will stall wider adoption
of FOSS GIS.
I seriously want to like QGIS, but am having a tough
time of that presently. Are there other FOSS GIS
clients that can access, search through, and render
shapefile data better than QGIS? I'm presuming,
perhaps falsely, that uDig is no better in
non-RDBMS-based spatial data access/render
performance.
Finally, have the QGIS, uDig, and other folks
considered joining forces to create a killer GIS
client? I find it depressing to see many different
fiefdoms in the FOSS community generally. If several
projects merged, it could lead to one heck of a FOSS
software product rather than, perhaps, several
marginal ones.
One of the beauties of FOSS is that anyone with a
vision can start a project and attempt to create
something better than already exists. However, that
vision may be realized, if ever, at a glacial pace. I
myself am impatient, and am not a software developer.
But if I was a developer, I would want to find the
best FOSS GIS client out there and focus efforts on
it.
Seems to me if people joined forces more often and
consolidated projects, QGIS, for instance, might not
still be choking trying to access, search, and render
moderately sized shapefiles after 5 years of
development.
So what gives? At conferences like FOSS4G, is there
ever talk of project consolidation? If not, why not? I
tend to think of all the development hours spent on,
say, 8 FOSS GIS clients, wasted, when, if
there was focus, 1 or 2 FOSS GIS clients could really
kick some butt and give commercial products real
competition.
Why doesn't project consolidation happen often--or not
often enough? Hurt feelings? Unwillingness to judge
one product over another?
Have there been no systematic attempts by the
community to seriously assess what projects are out
there, find 1 or 2 best of breeds, then encourage the
focus of development on those?
I appreciate all the work that's been done on QGIS,
uDig, and others. But I personally would love to see
more consolidation so we make larger, quicker strides.
Final question--if I import large shapefiles into
PostgreSQL/PostGIS, and use QGIS or uDig, will my
speed and usability gripes be extinguished? Honestly
can't ever imagine using the latest QGIS with
shapefiles for more than 10 minutes without wanting
immediately to uninstall it.
________________________________________________________________________
____________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
