[postgis-users] How best to do this?
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Feb 2 09:03:37 PST 2007
Paul, et al,
Any chance that someone would have GEOS 3 built for WinXP that I could
drop into a system currently running:
"POSTGIS="1.1.3" GEOS="2.2.2-CAPI-1.1.0" PROJ="Rel. 4.4.9, 29 Oct 2004"
USE_STATS"
"PostgreSQL 8.1.4 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
3.4.2 (mingw-special)"
So I could give this a try.
In the past, I seem to remember people dealing with these problems using
snaptogrid() - would this potentially help here and how would I change
my query to use that?
-Steve
Paul Ramsey wrote:
> GEOS 3 does include a number of fixes that will help difference and union.
> P
> On 1-Feb-07, at 9:01 PM, Stephen Woodbridge wrote:
>> OK, one step forward and two steps backward ...
>> I was about to get rid of my gemetrycollections with:
>> update newtable set the_geom =
>> (select geomunion(geom1) from
>> (select (dump(the_geom)).geom as geom1) as foo
>> where geometrytype(geom1)='POLYGON'
>> where geometrytype(the_geom)='GEOMETRYCOLLECTION';
>> This worked very nicely once I figured out that this was the way to
>> solve the problem. So now each geometry collection is converted into a
>> polygon or multipolygon and all the linestring and point artifacts of
>> the intersection are removed.
>> select distinct geometrytype(the_geom) from soils2;
>> POLYGON
>> MULTIPOLYGON
>> select * from soils where not isvalid(the_geom);
>> reports 0 rows
>> insert into newtable (..., the_geom)
>> select A....,
>> difference(A.the_geom, B.the_geom) as the_geom
>> from A, B
>> where A.the_geom && B.the_geom and overlaps(A.the_geom, B.the_geom);
>> NOTICE: TopologyException: no outgoing dirEdge found
>> (287030,892621,892621)
>> ERROR: GEOS difference() threw an error!
>> Now what do I do??? If I have to upgrade it might be easiest to
>> upgrade my WinXP laptop if there is an easy way to do that, then dump
>> and load the data to that.
>> select postgis_full_version();
>> "POSTGIS="1.1.5" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.4.9, 29 Oct
>> 2004" USE_STATS (procs from 1.1.1 need upgrade)"
>> select version();
>> "PostgreSQL 8.0.8 on i386-portbld-freebsd5.3, compiled by GCC cc (GCC)
>> 3.4.2 [FreeBSD] 20040728"
>> -Steve
>>> Hi all,
>>> Sorry the subject line is not more useful, but let me explain.
>>> 1) I have a set of polgons A and another set of polygon B
>>> 2) I need to a new set of polygons C that are the union of
>>> A intersect B and A difference B
>>> So basically B partially covers A and I want to split polygons in a
>>> into the covered piece(s) and that that is not covered.
>>> On the surface this is very straight forward, but it isn't ...
>>> insert into newtable (....)
>>> select ..., intersection(A.the_geom, B.the_geom) as the_geom
>>> from A, B
>>> intersects(A.the_geom, B.the_geom);
>>> This works, but I get a bunch of GEOMETRYCOLLECTION objects in the
>>> results and out of 1022 collection I have 2780 additional POLYGONs.
>>> So I could do something like:
>>> select * from
>>> (select ..., (dump(the_geom)).geom as the_geom from newtable
>>> where geometrytype(the_geom)='GEOMETRYCOLLECTION' ) as foo
>>> where geometrytype(the_geom)='POLYGON';
>>> delete from newtable where geometrytype(the_geom)='GEOMETRYCOLLECTION';
>>> So now comes the tricky part how do you do the difference? I was
>>> thinking I could take A difference newtable but because I have
>>> multiple little pieces instead of a single piece, I think I am getting:
>>> (A - Part1), (A - Part2), (A - Part3) instead of
>>> (A - Part1 - Part2 - Part3)
>>> So I think I need to union the polygon pieces from each row that is
>>> dumped above. Is that as simple as tossing part of the dump into a
>>> geomunion()? How would that look?
>>> -Steve W
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
