[postgis-users] Need an answer for somebody new to GIS and PostGIS
Paul Ramsey
pramsey at refractions.net
Sat Feb 3 11:34:59 PST 2007
Brian, you haven't shown us your data, or said exactly what you are
doing. Any attempt to assist you would be a shot in the dark. Explain
more precisely what you have tried so far, and I am sure you can find
help
Yours,
Paul
On 3-Feb-07, at 11:26 AM, Brian Harbick wrote:
> I have a data set of 1 million rows of addresses that have lat/
> long. I do not know the source of the geocoding.
> I need to be able to query the database for addresses within 10
> miles of a point.
> I have compared my attempts with results with results from Google API.
> On one address, google said it was 8 miles away. PostGIS results
> said 4 miles. Since, I live in the area that I tested 8 miles is
> most likely the correct answer.
> I have tried using SRID -1 and 4326 and both do not match with google.
> I admit I have been hacking at this for two weeks and read hundreds
> of posts in the forum, but have not found an answers that I can
> rely on.
> I think that PostGIS is meant for point in polygon type queries,
> which I will need next. but, right now I am just trying to make
> sure I understand how to setup the geometry correctly to test for
> miles.
> Please help point in the right direction with as much detail as
> possible.
> Thank You.
> postgis-users mailing list
