[postgis-users] How to move polygons? (by new point or vector)
Marc Compte
mcompte at sigte.udg.es
Tue Feb 6 06:50:02 PST 2007
Hi maciek,
I am trying to guess a way to do so and I haven't really check it
myself, anyone correct me if I am wrong.
I believe you can use the translate function ( =>
Translate(geometry,float8,float8,float8)) to move a geometry. If I'm not
wrong X and Y are not the final coordinates but the distance the polygon
needs to move to get to your new coordinates.
In that case you could do something like:
1. User clics on the map. You should be able to get the coordinates of
that particular point (Xpoint, Ypoint).
2. Calculate the centroid of the polygon to be moved using PostGIS's
function => Centroid(geometry). This returns a point identifying the
center of your polygon (Xcentroid, Ycentroid).
3. Calculate the distance on each of the axis between point and centroid
DistanceX=Xpoint-Xcentroid
DistanceY=Ypoint-Ycentroid
4. Move the polygon to the new location using
Translate(geometry,DistanceX,DistanceY,0)
Hope this helps a bit,
Marc
En/na Maciej Skorczewski ha escrit:
> Hi all!
> is there any postgis function who can move polygon on some vector?
> I store lot of polygons in database , user should move it in another
> place. Is it posible to do?
> for ex. i show new point of map and then i punt selected polygon in
> this palce.
> maciek
> postgis-users mailing list
