[postgis-users] Invalid Geometries from shapefiles
Paul Ramsey
pramsey at refractions.net
Wed Feb 7 09:52:42 PST 2007
If someone wants to fun CleanGeometry(), I am all ears :) There is no
magic bullet to make invalid geometries valid, but invalidities tend to
fall in a few major categories, so a CleanGeometry() could be fairly
effective.
In the meantime, do this, perhaps:
update yourtable set the_geom = buffer(the_geom,0.0) where not
isvalid(the_geom);
If that doesn't work, try running a snaptogrid() inside the buffer with
a very small tolerance. Both buffer and snaptogrid tend to squash out
invalidities, in many (but not all) cases.
Paul
Bruce Rindahl wrote:
> I have an application that stores floodplains in a PostGIS database for
> later display in a web mapping application. The floodplains are derived
> from shapefiles and are converted using shp2pgsql. The issue is some of the
> shapes are invalid when converted to the geometry format in PostGIS. When
> these invalid geometries are manipulated by certain operators, the results
> are not as expected (for example intersection returns a geometry collection
> instead of a multipolygon).
> Are there some guidelines or things to look for in shapefiles to assure the
> geometry is valid? Most of the problems occur when a polygon has an
> interior island. All of the tools we are using accepts these shapefiles as
> valid but will cause problems when converted.
> Thanks
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
