[postgis-users] within_distance function
Obe, Regina robe.dnd at cityofboston.gov
Fri Feb 9 12:32:47 PST 2007
I was hoping to simplify some of my distance queries by creating a
within_distance function which looks like
CREATE OR REPLACE FUNCTION within_distance(geom1 geometry, geom2
geometry, dist double precision)
  RETURNS boolean AS
$BODY$
BEGIN
 return  (expand(geom1, dist) && geom2 AND distance(geom1, geom2) <=
dist) ;
END;$BODY$
  LANGUAGE 'plpgsql' IMMUTABLE;
Upon testing this I noticed the following observations
SELECT l.pid, l.the_geom
FROM landparcels l , landparcels l2
WHERE l2.pid = '1803570000' and within_distance(l.the_geom, l2.the_geom,
1000) ;
runs in 1610ms and returns 679 rows
FROM landparcels l, landparcels l2
WHERE l2.pid = '1803570000' and (expand(l.the_geom, 1000) && l2.the_geom
AND distance(l.the_geom, l2.the_geom) <= 1000)
runs in 609 ms and returns 679 rows
WHERE l2.pid = '1803570000' and (distance(l.the_geom, l2.the_geom) <=
1000)
runs in 5437 ms and returns 679 rows
I ran the test a couple of times with similar results.  So apparently as
far as I can tell, my function is probably using my gist indexes, but
why is it 1/2 the speed of the regular expand call?
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070209/b3ddabf8/attachment.html>
