[postgis-users] Re: postgis-users Digest, Vol 52, Issue 9
Tim Bowden
tim.bowden at westnet.com.au
Sun Feb 11 21:11:23 PST 2007
On Sun, 2007-02-11 at 18:55 -0800, Ragi Y. Burhum wrote:
> On 2/11/07, Frank Koormann <frank.koormann at intevation.de> wrote:
> * Ragi Y. Burhum <ragi at burhum.com> [070210 08:01]:
> > > > ZigGis 1.1 available!
> [7]http://postgis.refractions.net/pipermail/postgis-users/2006-December/014217.html
> > > > HTH,
> > > > Frank Koormann
> > > It's still alive! Looks more promising. Thanks
> Frank. It's a read only
> > > job for now, but still useful.
> > As far as commercial products, you can use the Data
> Interoperability
> > Extension
> > [8]http://www.esri.com/software/arcgis/extensions/datainteroperability/index.html
> > for Read/Write.
> Has anybody used this "Write" already or is it just a legend?
> Looking at the "Data Interoperability" sheet [1] I find
> columns for Direct Read, Data Import and Data Export. No
> Direct Write.
> Regards,
> Frank Koormann
> [1]
> http://www.esri.com/library/fliers/pdfs/data-interop-formats.pdf
> Frank Koormann <
> Professional Service around Free Software
> (http://intevation.net/)
> FreeGIS Project
> ( http://freegis.org/)
> PostGIS Support
> (http://www.intevation.net/geospatial/postgis-support.en.html)
> I haven't personally used it for editing Postgis (I have for other
> datasources), however Safe's FME (which are the libraries used by
> Data Interop Extension)
> http://www.esri.com/industries/electric/resources/data/safesoftware.html lists Postgis as read/write http://www.safe.com/products/fme/formats-supported/index.php . You may want to double check with FME and/or ESRI to see what's the story.
> Hope this helps.
Thanks,
This is something we will have to look at. It's a pity there's no
comparable OS option :-(
Regards,
Tim Bowden
