[postgis-users] joining "nearest" data
Obe, Regina
robe.dnd at cityofboston.gov
Tue Feb 13 07:20:19 PST 2007
What't the nextval('climate_id_seq') in your view for? Also wouldn't
all your weather data have sites - seems like it should be sites LEFT
OUTER JOIN weather.
Here is my thought on how to get the nearest solar using a subselect
that finds the mindistance between a station and a solar point. You may
get more than one record if there are more solar locations equidistant
from your station in close proximity to station.
SELECT nextval( 'climate_id_seq' ), sites.station_id, sites.longname,
sites.lat, sites.lon, sites.thepoint_meter,
weather.date, weather.year, weather.month, weather.day, weather.doy,
weather.precip, weather.tmin, weather.tmax,
weather.tmean, weather.snowfall, weather.snowdepth, solar.date,
solar.year, solar.month, solar.day, solar.doy,
solar.rad, solar.dss, solar.par
FROM (weather LEFT OUTER JOIN sites USING (station_id))
LEFT JOIN
(s.station_id, min(distance(s.thepoint_meter,
sol.thepoint_meter) as mindist FROM solar sol, sites s GROUP BY
s.station_id) solmin
ON solmin.station_id = sites.station_id AND (solar.station_id =
solmin.station_id or distance(station.thepoint_meter,
solar.thepoint_meter) = solmin.mindist )
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Kirk
Wythers
Sent: Tuesday, February 13, 2007 9:06 AM
To: PostGIS Users Discussion
Subject: [postgis-users] joining "nearest" data
postgis-ers,
I have a tricky query to figure out (well... tricky for me anyway). I
have a climate database that consists of three tables:
table1 - site and geometry data
table2 - temperature and precip data
table3 - soar radiation data
I have constructed a join that combines these tables into a single
view. The trouble is that there are some sites that contain only
solar radiation data, and some sites that contain only temp and
precip data. In some cases sites with solar data are very close to
the temp and precip sites (less than a km away), but in other cases,
the nearest solar site may be 10s of km away.
I would like to be able to create a join where the "nearest" solar
data is joined to the temp and precip data.
How difficult would this be?
Here is the join statement that seems to grab everything but the
sites that contain only solar data:
FROM (weather LEFT OUTER JOIN sites USING (station_id)) FULL OUTER
JOIN solar USING (obs_id)
Thanks,
Kirk
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
