[postgis-users] joining "nearest" data
Kirk Wythers
kwythers at umn.edu
Tue Feb 13 16:45:26 PST 2007
On Feb 13, 2007, at 5:01 PM, Obe, Regina wrote:
> SELECT station_id, distance(s.thepoint_meter, sol.thepoint_meter)
> As dist
> FROM station s, solar sol
> (you are right I'm aliasing station s and sol for solar and I made
> the possibly incorrect assumption that you have a thepoint_meter in
> your solar table. If you don't you'd have to do another alias join
> with station to get the point location.).
I'm still struggling with this part Regina. thepoint_meter is not in
the solar table. geometry is in the sites table only (there is no
station table, station_id is a column name). So I will need to do a
third join (sites on solar). If I follow you correctly.
I have simplified my select with aliases (so it's shorter), removed
the nextval bit, and now have:
SELECT w.obs_id, sites.station_id, sites.longname, sites.lat,
sites.lon, sites.thepoint_meter,
w.date, w.year, w.month, w.day, w.doy, w.precip, w.tmin, w.tmax,
w.tmean, w.snowfall, w.snowdepth,
s.date, s.year, s.month, s.day, s.doy, s.rad, s.dss, s.par
FROM (sites LEFT OUTER JOIN weather w USING (station_id))
FULL OUTER JOIN solar s USING (obs_id)
However, I am confused on part where I need to do an alias join of
the sites.thepoint_meter with solar. I think what I need is these
three joins. (I was getting lost in all the parentheses):
FROM sites LEFT OUTER JOIN weather w USING (station_id)
FROM sites LEFT OUTER JOIN solar s USING (station_id)
FROM w FULL OUTER JOIN s USING (obs_id)
Sorry for making this such a struggle.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070213/23fdf168/attachment.html>
