[postgis-users] problem with buffer srid
Paul Ramsey
pramsey at refractions.net
Wed Feb 14 12:34:53 PST 2007
Markus Schaber wrote:
> Hi, Galois,
> "Galois" <galois at mundo-r.com> wrote:
>> I´m wondering what happens when you make a buffer from a geom with a srid. I´ve just buffered one geom but it has no srid (-1), is it normal? I´ve got a line table ( from which i buffered) and a point table ( which want to compare with the buffer), both the same srid. But the buffer maked from the line geom don´t have srid assigned and postgis doesn´t permit me to compare.
> So you say, that buffering loses the srid? I'm tempted to regard this
> as a bug.
I would too, but it doesn't occur on my version:
select asewkt(buffer(setsrid(makepoint(0,0),4326),1));
What version are you using that exhibits this behavior?
>> My answer is, how can i buffer something and obtein the resuls with the source-srid?
> setsrid(buffer(yourgeom, 42), getsrid(yourgeom))
> Regards,
> Markus
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
