[postgis-users] What's wrong with this point field?
Kurt Schwehr
schwehr at ccom.unh.edu
Thu Feb 15 17:38:42 PST 2007
Thanks for the explanation! I think I will stick with all lower case
from now on.
-kurt
On Feb 15, 2007, at 5:46 PM, Paul Ramsey wrote:
> Kind of. PostgreSQL is case-insensitive, "sort of", and it is the
> "sort of" which has bitten you. If you do:
> CREATE TABLE Foo ( Bar integer );
> You'll get a table with foo and bar coerced down to lowercase.
> If you do:
> CREATE TABLE "Foo" ( "Bar" integer );
> You'll get a table that preserves your original case, *but* in
> order to access the table and attribute names, all you references
> to them must now use the right case and use "" to enclose.
> Because PgSQL can do mixed case, PostGIS must respect that, and
> when you did SELECT AddGeometryColumn('position','Pos',-1,'POINT',
> 2) using a mixed-case attribute name, PostGIS respectfully
> preserved your case. Which means now you must use "" to reference
> it henceforth.
> You'll find that:
> INSERT INTO position ("Pos") VALUES ...
> works. You might want to start again and do pos in lower case, for
> your future sanity.
> Paul
> Kurt Schwehr wrote:
>> Hi All,
>> I am at a loss for what I am doing wrong here. I am using
>> postgres 8.2.3 and postgis 1.2.1 on mac osx 10.4.8 with fink
>> provided packages.
>> CREATE TABLE position ( key SERIAL PRIMARY KEY, MessageID INTEGER,
>> RepeatIndicator INTEGER, UserID INTEGER, NavigationStatus INTEGER,
>> ROT INTEGER, SOG DECIMAL(4,1), PositionAccuracy INTEGER, COG
>> DECIMAL(4,1), TrueHeading INTEGER, TimeStamp INTEGER,
>> RegionalReserved INTEGER, Spare INTEGER, RAIM BOOL, syncstate
>> INTEGER, slottimeout INTEGER, slotoffset INTEGER, cg_r VARCHAR
>> (15), cg_sec INTEGER, cg_timestamp TIMESTAMP ); SELECT
>> AddGeometryColumn('position','Pos',-1,'POINT',2);
>> ais=# INSERT INTO position (pos) VALUES (GeomFromText('POINT
>> (-122.778191666 48.277336666)'));
>> ERROR: column "pos" of relation "position" does not exist
>> Am I doing something really dumb?
>> Thanks,
>> -kurt
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Paul Ramsey
> Refractions Research
> http://www.refractions.net
> pramsey at refractions.net
> Phone: 250-383-3022
> Cell: 250-885-0632
