[postgis-users] PostGIS on OS X Tiger Server
P Kishor punkish at eidesis.org
Thu Feb 15 22:30:58 PST 2007
I am getting the following error --
checking for pg_config... no
configure: error: PostgreSQL is required by PostGIS
Details -- using Tiger Server, fwiw. Installed PostGres
 ./configure --with-perl --with-bonjour PERL='usr/local/bin/perl'
all is good.
per the instructions on PostGis website, untarred v. 1.2.1 inside pg/contrib
/usr/local/src/postgresql-8.2.3 punkish$ cp ~/postgis-1.2.1.tar.gz contrib
/usr/local/src/postgresql-8.2.3 punkish$ cd contrib
/usr/local/src/postgresql-8.2.3/contrib punkish$ tar xvzf postgis-1.2.1.tar.gz
/usr/local/src/postgresql-8.2.3/contrib punkish$ cd postgis-1.2.1
/usr/local/src/postgresql-8.2.3/contrib/postgis-1.2.1 punkish$ ./configure
checking host system type... powerpc-apple-darwin8.8.0
/usr/local/src/postgresql-8.2.3/contrib/postgis-1.2.1 punkish$ cd ../..
/usr/local/src/postgresql-8.2.3/ punkish$ find . -name pg_config
./src/bin/pg_config
./src/bin/pg_config/pg_config
On 2/15/07, Paul Ramsey <pramsey at refractions.net> wrote:
> I run on OS/X Tiger on the desktop, so I imagine no problems. Only
> thing I recall is that to get command completion and history in psql
> you need to install a recent version of readline before installing
> postgresql.
> P
> On 15-Feb-07, at 6:08 PM, P Kishor wrote:
> > Greetings,
> > I am going to install PostGres/PostGIS on Tiger OS X Server 10.4.8.
> > Before I rush into this, any caveats? Is PostGres 8.2.3 + PostGIS
> > 1.2.1 combo ok, esp. on Tiger Server?
> > Many thanks in advance,
Puneet Kishor http://punkish.eidesis.org/
Nelson Inst. for Env. Studies, UW-Madison http://www.nelson.wisc.edu/
Open Source Geospatial Foundation http://www.osgeo.org/education/
collaborate, communicate, compete
