[postgis-users] how to find zipcodes within the radius ofparticular zipcode.
Obe, Regina
robe.dnd at cityofboston.gov
Fri Feb 16 03:50:24 PST 2007
SELECT z.zipcode
FROM zipcode z, zipcode z2
WHERE z2.zipcode = '02109' AND expand(z2.the_geom, <whatever radius you
want goes here - but your spatial ref needs to be in that metric or you
need to convert the radius>) && z.the_geom AND distance(z.the_geom,
z2.the_geom) <= <radius goes here again>
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
vamsee movva
Sent: Thursday, February 15, 2007 11:51 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] how to find zipcodes within the radius
Hi
I am very sorry. I would have more clear in the last post.
I have zip codes defined by polygon and i have to find out zip codes
with in given radius.
Thanking you
cheers
satya
On 2/15/07, Pedro Doria Meunier <pdoria at netmadeira.com> wrote:
Hello Satya,
There's a lot of functions you can use but you must be more
specific as to what type of data are you using...
Like:
Are these zip codes defined by a polygon, point, what?
Please be more specific so that the list can help you ;-)
Pedro Doria Meunier
vamsee movva
Sent: quinta-feira, 15 de Fevereiro de 2007 22:49
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] how to find zipcodes within the radius
of particular zipcode.
Hello,
How to find zipcodes within the radius of particular
zip code.
Thanks in advance.
cheers
satya
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070216/81bc5720/attachment.html>
