[postgis-users] Makefile syntax problem with 1.2/8.2?
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Mon Feb 19 04:49:13 PST 2007
On Mon, 2007-02-19 at 10:01 +0100, Thy, Kristian wrote:
> As far as I can tell the upshot of this was that the problem is best
> fixed by upgrading libgeos. I'm stuck with libgeos 2.1 - can anybody
> confirm that Devrims .configure patch solves the problem without
> introducing other errors?
Hi Kristian,
Which version of PostGIS are you using? The configure patch should work
fine, since it it had already been applied to the SVN repository before
the latest 1.2.1 and 1.1.7 releases - perhaps the FC6 repositories
haven't yet picked up these updates?
Kind regards,
Mark.
