[postgis-users] import SHP into postGIS - still error - but it is closer
luca marletta
lucamarle at gmail.com
Tue Feb 20 02:24:57 PST 2007
this my notes about.
Try to adapt the below commands
# shp2pgsql –s <epsgcode> shapename.shp myschema.newtable > dump.sql
# iconv -f "ISO-8859-15" -t "UTF-8" roads.sql (if you need it!)
# psql -d dbname -U postgres -f dump.sql
with your cooding before load into postgis, on the sql file
luca
On 2/20/07, Maciej Skorczewski <maciej.skorczewski at procad.pl> wrote:
> hello again!
> so i start new database with latin2 encoding.
> ogr2ogr start generate table
> CREATE TABLE osienazwy
> ogc_fid serial NOT NULL,
> wkb_geometry geometry,
> id double precision,
> idulicy double precision,
> ulica character(30),
> "pełna" character(100),
> id1 double precision,
> id2 double precision,
> kier2 character(1),
> length numeric(31,15),
> idodcinka double precision,
> CONSTRAINT osienazwy_pk PRIMARY KEY (ogc_fid),
> CONSTRAINT enforce_dims_wkb_geometry CHECK (ndims(wkb_geometry) = 2),
> CONSTRAINT enforce_geotype_wkb_geometry CHECK
> (geometrytype(wkb_geometry) = 'LINESTRING'::text OR wkb_geometry IS NULL),
> CONSTRAINT enforce_srid_wkb_geometry CHECK (srid(wkb_geometry) = -1)
> WITHOUT OIDS;
> ALTER TABLE osienazwy OWNER TO postgres;
> but after 4599 added row (shp file have about 15.000 row of street) i
> get error massage (look on url)
> http://img87.imageshack.us/img87/7464/mapabc9.jpg
> guestion: what can i do whit this?
> maciek
> postgis-users mailing list
luca marletta
www.beopen.it
