[postgis-users] Dilemma: is gid really useful in a geoDB?
Antonello
antonello.monetsen at gmail.com
Fri Feb 23 01:17:01 PST 2007
Thanks a lot to all of you!
This discussion revolve all my doubt about the use of gid, Thanks! I
start the modeling of my database with the purpose to build a standards
geoDB which I could use with several free, and eventually, no-free
application. So I was scared that maybe gid was a standards for identify
the feature in a layer. But after yours help I have a clear idea about it.
Thank you a lot, bye Antonello.
Mark Millman wrote:
> The problem is that the original SHAPE file doesn't have any attributes. It
> has attribution only by a one-to-one row correlation with an associated DBF
> file. Therefore the only way to associated the geometries found in the
> SHAPE file with the non-spatial attribution found in the DBF file is by the
> row number. Blame ESRI and 30 years of history on this one.
> The argument of using a automatic number or sequence as opposed to "natural"
> data as a primary key is an old one and both sides of the argument have
> validity. Simple numbers index faster, join faster, and are found in almost
> every database I've ever seen; however they are intrinsically meaningless.
> But there are a lot of "John Smith"s in the world so we invent things like
> Social Security Numbers and GIDs.
> Historically GIS has supported many data sets that have no attribution,
> other than their feature name; or they do have a unique "natural" attribute.
> There are a lot of edges to the Mississippi River and I'd hate to have to
> come up with a meaningful naming convention to keep them all unique. One
> might be tempted to use a distance criteria; until one remembers that rivers
> move and the next elbow that is cut off would result in changes that would
> be very difficult to manage. So the only opportunity for a primary key is
> the something like a GID.
> So something like GID is important if you want to associate records that do
> not have "natural" keys or if you want to avoid seriously long primary keys
> like "USA,WA,Whatcom,Bellingham,Mill Ave,1340" for a primary key.
> There is another argument for the use of a GID-like key and that is the
> separation of spatial data from attribution, in a manner similar to that
> used by some CAD based GIS like Bentley's Geographics and Intergraph's old
> MGE. These systems allowed for a single spatial instance to serve as a
> topological boundary to many themes. A single polyline could be the
> boundary of a River, Municipality, County, and State; all at the same time.
> Adjusting the line changed the all the associated boundaries simultaneously.
> Geographics created topology dynamically based on the boundaries and
> requested themes. Themes had display priority so that the line was always
> rendered appropriately for the senior most theme in the display list.
> There are reasonable arguments in favor of such model in a purely database
> solution too. Each of the themes could have a foreign key to a common
> spatial data table rather than embedding the spatial data directly in the
> "theme" record. This would avoid duplication of data, avoid double
> plotting, and allow applications to manage shared boundaries consistently.
> Mark Millman
> Mizar, LLC
> mark.millman at mizar.com
> www.mizar.com
> 589 S Beach Rd.
> Point Roberts, WA 98281
> (360) 945-2643
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Havard
> Tveite
> Sent: Thursday, February 22, 2007 3:07 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Dilemma: is gid really useful in a geoDB?
> In the relational model, the primary key can be a combination
> of several attributes. If you have such a combination of
> attributes, there is (from the relational model's point of
> view) no need for a separate gid.
> Also, if geometry is considered fist class data type of the
> (extended) relational model, location itself can, in principle,
> act as (or be a part of) a primary key (as long as you can
> guarantee that there is only one object per location).
> As pointed out in several other postings, the "problem" is that
> a lot of GIS software tend to rely on having a single attribute
> primary key, and that this key has to be of a specific type.
> The system (PostgreSQL) generated "oid" can also be used as a
> primary key.
> Håvard
> Marc Compte wrote:
>> Hi,
>> Ermm ... wasn't one of Codd's rules "Each and every datum (atomic value)
>> in a relational data base is guaranteed to be logically accessible by
>> resorting to a combination of table name, primary key value and column
>> name."?
>> I find it surprising to see that "there's no need for a gid, from the
>> database point of view" and that primary keys are only needed because
>> "most applications want some way of identifying specific rows", as the
>> very core definition of the relational model clearly identifies this as
>> a crucial part of the model. Wanting to identify specific rows is not an
>> application oddity, it's part of the very definition of the model.
>> Every table needs to have a key, not only to conform with the relational
>> model's theory, but for pragmatical purposes as well. Even (or
>> specially) from the database point of view, no key means there is no way
>> to update a unique field, there is no way to extract the information
>> about one individual record, there is no way to cross-reference tables
>> ... in short, no key means something like there is no relational
>> database, only a flat list of data ... and PostgreSQL, even though it
>> incorportes OO elements, has still a big part of relational, right?
>> Whether you have to be using that particular field (gid) or not depends
>> on your data. I don't think naming your key field "gid" is defined in
>> any standard (it shouldn't be anyway). As other people said, shp2pgsql
>> automatically generates this one for you, but I assume that is just to
>> make your life easier and make sure there is at least one way to
>> uniquely identify records.
>> The only important thing to do should be to make sure that there's at
>> least 1 field with values that can be used to uniquely identify any of
>> the records of your table. If you are sure there's another field (or
>> combination of fields) that serves the purpose right, you wouldn't
>> actually need to have that particular gid field. You should be able to
>> delete it and still be able to use on that table all of the features of
>> the database and any other surrounding application by using your own
>> self-made primary key.
>> If an application has a problem with any of this (multiple field keys,
>> using a different name for the key field other than gid, ...) then you
>> could probably say it is not well designed and you might want to switch
>> to something else.
>> Marc
>> En/na Markus Schaber ha escrit:
>>> Hi, Antonello,
>>> Antonello <antonello.monetsen at gmail.com> wrote:
>>>> I have a dilemma: is gid really useful in a geoDB?
>>>> I am building a geodb for several harbor. When I create a layer(table
>>>> with geometry) in postgis, I need a gid like a primary key, or I can
>>>> use a different one? Can I use several field of from the table like
>>>> a primary key?
>>>> I am not new in the gis, but why in almost all geoDB I saw there is a
>>>> gid?! Is it really necessary? Do it come from shapefile standards?
>>> Technically, there's no need for a gid, from the database point of
>>> view, as SQL deals with sets of rows.
>>> However, most applications want some way of identifying specific rows,
>>> especially when updating / editing data.
>>> GID is generated by shp2pgsql.
>>>> For example QuantumGIS doesn't work if the layer has only one primary
>>>> key, there are other application that don't work like qGis?
>>> QuantumGIS has the additional oddity that the primary key has to be of
>>> type int4 - int8 or serial (which is optimal for primary keys) is not
>>> accepted, AFAIK.
>>> For read-only access, you can try MezoGIS which makes very little
>>> assumptions about your database, and you can specify layers via
>>> arbitrary queries.
>>> Regards,
>>> Markus
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
