[postgis-users] How to Rotate a polygon.
Shoaib Burq
shoaib at nomad-labs.com
Fri Feb 23 06:36:07 PST 2007
Hi Maciek
Have a look at RotateZ(geometry, float8). It should do the trick.
http://postgis.refractions.net/docs/ch06.html#id2939343
Assuming you have a postgis database here is an quick example usage
CREATE TABLE shapes (gid serial PRIMARY KEY, name varchar);
SELECT AddGeometryColumn('', 'shapes', 'the_geom', -1, 'POLYGON', 2);
insert into "shapes" ("the_geom", "name") values (
'POLYGON((0 0, 0 5, 10 5, 10 0, 0 0))', 'lying down');
select AsText(RotateZ(the_geom, 0.7854)) from shapes where name = 'lying down';
see attached image for the output
hope this helps
shoaib
http://nomad-labs.com
On 2/23/07, Maciej Skorczewski <maciej.skorczewski at procad.pl> wrote:
> hi all!
> i am new in postgis my guestion is:
> how to rotate a polygon?
> The problem is that polygon suld be stay i start point - then i make
> rotation
> http://img213.imageshack.us/img213/6642/rotateiq7.jpg
> thx.
> maciek
> postgis-users mailing list
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070224/7dd26854/attachment.png>
