[postgis-users] problem in dynamic SQL with Mapserver
nimalika fernando nimalikaf at yahoo.com
Sun Feb 25 00:06:20 PST 2007
Hi everybody,
  I'm working with some post-disaster management support tool with mapping forcusing on Tsunami Rehabilation.
  I have managed to use postGIS / UMN mapserver for basic stuff like select data from different tables , join them and dislaying information according to predefined selections.
  Now I want to add a very simple serching facility. For an example if user already knows the name of an affected village name,by selecting the name ( from a drop down menu), the area should be highlighed on the map.
  I tried to pass user selection as a variable to postGIS query but I failed.
  code segment is as follows
  DATA "the_geom from (select alldsdivisions.the_geom as the_geom from alldsdivisions where alldsdivisions.dsd_n ='%qstring%')
   AS selectedgs
   USING UNIQUE oid USING SRID=-1"
  qstring is the variable name use in HTML file.It is replaced by user selection dynamically.
  alldsdivisions is the relation name and dsd_n is the column name of village names.
  i get following error message
  prepare_database(): Query error. Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT dsd_n::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),oid::text from (select alldsdivisions.the_geom as the_geom from alldsdivisions where alldsdivisions.dsd_n ='Ambalantota') AS selectedgs WHERE (Ambalantota) and (the_geom && setSRID( 'BOX3D(181659.373889 74242.41425975,303213.047119 165407.66918225)'::BOX3D,-1) )'
Postgresql reports the error as 'ERROR: column "dsd_n" does not exist '
but dsd_n column do exist .
  I can't figureout how to handle this.
  any help is highly appriciated.
  thanking in advance.
  nimalika
  ( from Sri Lanka-island in indian ocean)
Finding fabulous fares is fun.
Let Yahoo! FareChase search your favorite travel sites to find flight and hotel bargains.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070225/1706c8b1/attachment.html>
