[postgis-users] Problem : Within() incorrectly returns 'false'
Martin Davis mbdavis at refractions.net
Mon Jan 8 11:16:51 PST 2007
Ok, I'm just reporting from the JTS algorithm perspective.  This will
have to be addressed by Sandro or someone else who can try this out in
PostGIS/GEOS.
Arnaud Lesauvage wrote:
> Martin Davis a écrit :
>> I'm not sure about this one.  The test checks out fine in JTS.
>> But note that you have some <CR>s in the text of the Polygon geometry
>> which occur in the middle of coordinate values, and which if actually
>> present in the string cause invalid geometry to be created.  If
>> you're running this SQL from a script, then you should closely
>> inspect the script to make sure that the cmd is either all on one
>> line or the line breaks do not split numeric values.
> Hi Martin,
> The geometries are stored in tables. I wrote their WKT representation
> so that anyone could reproduce the problem.
> Have you tried running this in psql ?
> I really don't get it here...
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
