[postgis-users] Compiling PostGIS on windows
Obe, Regina robe.dnd at cityofboston.gov
Tue Jan 9 14:21:47 PST 2007
I was successful building postgis cvs against the PGXS Development
header files included with the PostGreSQL 8.2.1 under the MinGW/Msys.
Although I haven't tested it yet.  I ran into compilation errors with
the Geos-2.2.3 piece something about  'redefinition of `struct timezone'
in geos ../timeval.h and redefinition in include/sys/time.h which I'm
checking out.
To compile I had to
configure --with-pgsql="C:/PROGRA~1/POSTGR~1/8.2/bin/pg_config"
I ran into one problem in that the c.h in the PostgreSQL 8.2 refered to
a libintl.h which was not distributed with the 8.2 development files.  I
had to get this from gettext and copy into my 8.2/includes path.  Is
there a legal reason why they wouldn't distribute this file or you think
it was just an oversight.  I was going to ask the same question in
pghackers.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Monday, January 08, 2007 11:10 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Compiling PostGIS on windows
On Mon, 2007-01-08 at 10:38 -0500, Obe, Regina wrote:
> Is it still necessary to compile the PostgreSQL tree first to compile
> PostGIS?  I thought enhancements in PostgreSQL 8.1 allowed for
> building contribs just against the header files or PGXS files, but I
> haven't seen any documentation to that effect.
> Thanks,
> Regina
Hi Regina,
The answer is "maybe". For the Win32 installers, I have a separate
PostgreSQL source tree with lots of debugging options enabled to help
capture any bugs found running the regression tests. So as I don't build
in this way, I'm afraid you'll just have to try it and see. My feeling
is that it should work, but you may have issues converting between
MingW/Windows paths.
Kind regards,
Mark.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
