[postgis-users] pl/pgsql question: dynamic access to record.column
Dylan Beaudette
dylan.beaudette at gmail.com
Wed Jan 10 14:04:10 PST 2007
On Wednesday 10 January 2007 13:10, Mark Cave-Ayland wrote:
> On Wed, 2007-01-10 at 12:24 -0800, Dylan Beaudette wrote:
> > I am learning how to use PL/PGSQL and have come upon something that I
> > just don't seem to be able to solve on my own.
> > I have a function, which takes a column name as an argument. A FOR loop
> > iterates over rows, using a RECORD datatype to store each iteration of
> > the loop.
> > If I hard-code in a column name into some calculation, things work fine.
> > However, I cannot seem to figure out how to _dynamically_ access a column
> > from a RECORD datatype:
> > -- this works fine : 'field_pct_clay' is a hard-coded column name
> > DEFINE
> > hz_record RECORD;
> > wt_column FLOAT;
> > thick FLOAT;
> > wt_column := wt_column + (hz_record.field_pct_clay * thick) ;
> > -- this does not work: 'the_column' is an argument to the function being
> > defined:
> > wt_column := wt_column + (hz_record.the_column * thick) ;
> > obviously, the interpreter tells me that there is no column named
> > 'the_column' in the RECORD iterator...
> > Searching on google, it seems that a dynamic expression like this needs
> > to be evaluated with the EXECUTE keyword.... However something like this
> > does not work:
> > wt_column := EXECUTE 'wt_column + (hz_record.' || quote_ident(the_column)
> > || ' * thick)' ;
> > any tips would be a great help!
> > thanks!
> Hi Dylan,
> You'll need to post the entire stored procedure for this one so that we
> can tell the difference between PL/PGSQL variables and column names.
> Kind regards,
> Mark.
Thanks Mark, please find the entire procedure below:
CREATE OR REPLACE FUNCTION depth_wt_avg (
the_pedon_id varchar, top_lim numeric, bottom_lim numeric, the_column
varchar )
RETURNS FLOAT as $$
DECLARE
-- horizon variables, use a record datatype
hz_record RECORD;
thick FLOAT :=0 ;
thick_total FLOAT :=0 ;
wt_column FLOAT :=0 ;
wt_column_avg FLOAT :=0 ;
-- flags detecting when the defined limits intersects a horizon
intersects_top_flag integer ;
intersects_bottom_flag integer ;
BEGIN
FOR hz_record in
EXECUTE 'select top, bottom, '
|| ' from horizon '
|| ' where pedon_id = '
|| quote_literal(the_pedon_id)
|| ' and ( bottom >= '
|| top_lim
|| ' and top <= '
|| bottom_lim
|| ' and '
|| ' is not null'
|| ' order by top '
LOOP
-- use something like this for each horizon, to create
PCS_intersects_top_flag, PCS_intersects_bottom_flag
select into intersects_top_flag
CASE WHEN top_lim > hz_record.top and top_lim < hz_record.bottom THEN 1
ELSE 0 END ;
select into intersects_bottom_flag
CASE WHEN bottom_lim > hz_record.top and bottom_lim < hz_record.bottom
THEN 1 ELSE 0 END ;
-- if the PCS does not overlap this horizon
thick := hz_record.bottom - hz_record.top ;
-- else use the top of the PCS instead
IF intersects_top_flag = 1 THEN
thick := hz_record.bottom - top_lim ;
END IF;
-- else if we are at the last horizon use the bottom of the PCS as the
bottom cutoff
IF intersects_bottom_flag = 1 THEN
thick := bottom_lim - hz_record.top ;
END IF;
-- sum the horizon thickness within the PCS
thick_total := thick_total + thick;
-- the weighted clay percent, and frags pct
EXECUTE 'select ' || wt_column || ' + (' || 'hz_record' || '.' ||
quote_ident(the_column) || ' * ' || thick || ')' into wt_column;
-- the weighted-avg clay percent and frags within the PCS
wt_column_avg := wt_column / thick_total;
END LOOP;
RETURN round(wt_column_avg::numeric, 1) ;
END
$$ LANGUAGE plpgsql;
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
