[postgis-users] Establishing a remote connection to postgis
Obe, Regina
robe.dnd at cityofboston.gov
Fri Jan 12 04:51:49 PST 2007
Can you connect to your postgres from the server its on? As I recall
the erroneous pg_hba file usually means you have a malformed pg_hba.conf
like perhaps you have a funny character in there or its not pointing to
your pg_hba file at all.
Is your pg_hba.conf file in your postgresql data directory and does the
account you are running postmaster under have rights to that file?
I think if it was pointing to it and it was well formed, but you just
weren't allowing the ip thru, you get something like a "connection
refused" error not a "erroneous pg_hba conf file" error.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
David Potts
Sent: Friday, January 12, 2007 3:47 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Establishing a remote connection to postgis
Try
host all all 10.1.1.5 255.255.255.255 md5
> Hi all,
> I try to connect to my postgis db on a remote server. I use Quantum
> GIS
> 0.7.4 and Udig 1.0.6 for doing this.
> When I try to connect I get the following error message, in both of
> the
> applications:
> So I look at my pg_hba conf file. I have added this line to the pg_hba
> conf file in order to estabalish connections from outside my LAN.
> host all 127.0.0.1 255.255.255.255 md5
> For now it looks like this:
> # TYPE DATABASE USER CIDR-ADDRESS METHOD
> # IPv4 local connections:
> host all all 127.0.0.1/32 md5
> # IPv6 local connections:
> #host all all ::1/128 md5
> I've tried to find the "tcpip_socket" connection parameter, but I
> can't seem to find it in the postgresql.conf file, using PostgreSQL
> 8.1...
> Following that I've started the postmaster with the -i flag and -D-
> flag pointing to my data directory.
> Can someone help me out ?
> Thanks in advance
> postgis-users mailing list
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
